  1. Hi,
    I ripped a dvd(it was a two disc set, this onbe did not have the special features) and got 7 gigs of vob files, and usedifoppedit to eliminate forign languages and subtitles. My question is: Are there any other things that can be stipped from the files to lower their size, but not affect the movie?
  2. Member wulf109's Avatar
    Jul 2002
    You need to transcode the vob files to a lower bitrate,therefore smaller file size. There's a program called Rempeg that can do this and it's works in conjunction with Ifoedit to convert them to a smaller size that will fit on a DVD-R. You could also do it in Tmpeg but that would then require you to re-author the files into DVD format.
