I've just started using TMPGenc. My system is a 1.2ghz with Windows XP Pro, Divx 5 and TMPGenc latest version.
I have a DIVX file of 700mb, 72 minutes long.
The weird thing is it says it is 23fps and in a weird format (576 x 240) I tried running the convert and TMPGenc came up with a constant, recurring error (just loads of numbers on an "error" popup)
Any ideas?
I've found out!
Using Nero, I simply copied the AVI (with Codecs installed) onto the VCD template.
It worked first time.
HOWEVER,
I've found that whilst trying to encode it, it jumps! It goes for a few seconds and then there seems to be a few milliseconds hold and then it continues. It's watchable as my TV can decode 4:3 and stretch it into 16:9 (ok it's not 2.35:1 but better)
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 09:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 01:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 13:28 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 11:53
