I was wondering how to change the disk size on dvd2svcd cause when it make a mpg file is to ig on disk 1 every time and the bin/cue it makes chop so i use the mpg file and the 1st disk is always to big and i was wondering if i could change the disk size on the disk and make them under 790 cause disk 2 is 793 and it fits but disk 1 is 795 and dont fit it too big it says and i use nero can any 1 help me pls
ScootZilla
In the "bitrate" tab for "CD Size" it looks like it's a drop down menu but you can actually type in any number, so just type in 795 or whatever size you want.
-LeeBear
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Converting 2-Disk Sets to 1 Disk
By 1337assassin in forum Newbie / General discussionsReplies: 18Last Post: 23rd Oct 2010, 09:53 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
BD Rebuilder - What Size Disk Are You Making
By wulf109 in forum Blu-ray RippingReplies: 9Last Post: 15th Dec 2009, 19:52 -
Creating / converting DVDs with Devede: Disk usage bar underestimates size!
By nicolaidenmark in forum LinuxReplies: 4Last Post: 22nd Aug 2008, 23:09
