  1. Hi,
    I ripped a dvd, and got 7 vob files, totaling 7 gb. I only want the video, and english sound tracks. I know there are 8 language tracks, but do not know how do delete them from the vob files. As such the file size is much greater then it should be.
    Can anyone help me remove the additional audio tracks?
    Thanx
    May 2001
    Gee, what DVD has eight audio tracks?
    Use IFOEdit to load the VTS of the main movie, select STRIP STREAMS, then select the ones you want to keep. Point the product to another directory (hopefully on another HD), then press the start button. While you are at it, you might as well strip all the subpicture streams (subtitles) out, too.
