An affluent friend with broadband connection (I hate him!!) has just downloaded Signs (you know, the Mel Gibson movie) but its in two 810mb mpeg pieces (not DivX). Rather than re-encode it to mpeg 1 I thought it would be quicker to join it and cut it into useful sized segments and burn it to vcd or svcd as appropriate. The problem is I dont know if its mpeg 1 or 2. How can I tell?
Spence.
I would use this tool:
http://www.tecoltd.com/bitratev.htm
Chances are it is a PAL SVCD (a lot of the pirated SVCDs are PAL)...depending on your player you might be able to just burn it and play.
Regardless of the format, I wouldn't do any cutting or joining. Each of those 810 MB files will fit on a CD-R.End of Line.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 17:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 04:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 16th Dec 2008, 23:38
