OOOooOooOoo.... spooky! (couldn't help myself there, I'm in a weird mood)
Anyway, I have a little problem with ATI MMC 7.xx (using my Radeon), where my MPEG-2 captures are of EXCEPTIONAL quality, but I have an occasional "hiccup" where it drops some frames all at once, at random, makes audio desynch...
So, I'm looking for another MPEG-2 capture solution. The only one I can find is PowerVCR 2.
I've sucessfully configured it (though it seems I have to every time) to capture, and I have to force-crash the program to end capture, then save the "temp.mpg" file when you reload the program {pant, pant, gasp}, but ultimately I get what I meant to capture.
The problem is, whatever I'm capturing, whether Interlaced, or De-Interlaced, seems to be VERY good still-image quality, but foggy and ghost-like during any movement! This is using 5000k bitrate high quality!
I can check/uncheck all the options I can find (like Video Smoothing, Noise Removal, TSPSeek) but none seem to effect this.
Can someone (hopefully with some background in this proggy) offer some advice here? I'm fairly sure my problems will be over once I can defeat the ghostly images! (Famous last words)
Thanks!
How about a cookie by mail?
Seriously, I need some help!
Or, maybe should I try using MMC 6.3 witha a Radeon board? Which would be better?
Panasonic AG-1980 giving a ghostly smear with TBC on. Less noticeable w/out
By ruehl84 in forum CapturingReplies: 2Last Post: 8th Feb 2012, 11:04 -
images
By AlanHK in forum TestReplies: 4Last Post: 4th Mar 2010, 13:12 -
HD images
By toneystone in forum Newbie / General discussionsReplies: 3Last Post: 21st Oct 2008, 11:50 -
Powervcr II 3.0 Deluxe
By vijaye05 in forum CapturingReplies: 1Last Post: 7th Oct 2008, 04:30 -
images over/under exposed help
By natjan in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 10th Jul 2007, 06:11
