I am a newbie who is trying to use Roxio Easy CD Creator to burn a VCD using CD-R media. I followed the instructions provided at this web site (many thanks) and I can burn the VCD. However, it won't play with WinDVD or on my JVC DVD player. I tried to create a simple menu with four options. WinDVD will occasionally play a sinlge scene and starts in the middle but the menu never appears. My DVD player blinks PBC and chapter 1 but won't play anything. I can play the .dat files with Media Player and I got it to work with RealPlayer. I am burning/playing on a Dell Inspiron WinXP. I am also buring with the Disk-at-once option.
Help!!! Any ideas?
I am going to try to burn without the menus and see if that helps.
Try using nero to burn.
a lot of people around here recomend that you do not use roxio,
they say roxio is horrible
Hope this helps
VCD4MEWe were all NEWBIES once and the only stupid question is the one that's not asked? -
So was Roxio a waste of money? Can I create the file in Roxio Easy CD Creator and then burn using Nero?
Update: I tried to burn to a .cif file and then copy that to the CD instead of doing it all in one step and it seems to work fine. Still won't work in WinDVD, but is now playing on my DVD player and menus are working. :P
Burning DVD's with Roxio Creator Basic 9 or Windows DVD maker
By bhess55 in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2008, 02:55 -
Newbie Roxio easy cd and dvd burning question.
By mmmipa in forum Newbie / General discussionsReplies: 8Last Post: 24th Nov 2007, 21:31 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio Easy Media Creator 10 verses Pinnacle Studio 11
By snuggels in forum Newbie / General discussionsReplies: 3Last Post: 3rd Oct 2007, 12:10 -
Roxio Launches Easy Media Creator 10
By roxann in forum Latest Video NewsReplies: 0Last Post: 5th Sep 2007, 15:27
