Is it Possible to create vcd on dvd media
I have 3 vcd compliant mpg files that are approx 3.5 GB total and i would like to be able to put them and a single dvd disc as VCD format.
I have looked on this site and on others and i cant find helpful information If you have been able to do it, please clue me in
Thanks, Russ
Yes you can. I would suggest de-multiplexing to split your audio from the video, and resampling the audio, and then multiplex the two streams together again. That would be much faster than re-encoding.
Right. Go read the FAQ. It show you detail in step on how to do it without re-encoding. You don't even need to mux it back using SpruceUp or DVDMaestro.
i have scowered the faq i cannot find how to put multi vcd on dvd media and have it so it can play on my dvd player
You must not have looked very hard...
DVD-VCD
http://www.vcdhelp.com/vcddvdr.htm
DVD-SVCD
http://www.vcdhelp.com/svcddvdr.htm
Samples for burning compatability test here:
http://www.vcdhelp.com/dvd.htm#sample
Good luck! -
When i tried using spruceup it wanted to put it in dvd format.
all i really want is a program that will let me create a vcd menu for the movies i have and be able to burn it. (example - Nero if you choose VCD it will let me create a menu but if i try to burn to a dvd the burner spits out the dvdr and asks for a cdr even though it wants to burn 3.5 GB, VCDEasy - if i add a file larger than 700 MB it crashes with a "integer overflow error") -
I don't know why SpruceUp allows you to pick different target sizes. It only supports DVD, so the step seems pointless. SpruceUp will not let you work on VCD, or SVCD. It only does DVD.
For SVCD menu's, I like using DVD2SVCD. It's about as simple as it gets. Try any one of the GUI's for VCD's, or SVCD's. I haven't used all of these, so I don't know if they do menu's or not. You should be able to find them in the TOOLS section to the left.
DVD2SVCD
VCDImager
VCDEasy
VCDComposer
VCDWizard
TSCV
I know that some of these support menu's. Some probably make only the image file itself. Just browse their descriptions to find what your looking for.
tsmuxer errors with media type 15 when creating blu-ray content
By syeager in forum Authoring (Blu-ray)Replies: 4Last Post: 31st Mar 2010, 15:52 -
Total Media Extreme makes coasters when creating DVD-AVCHD
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 29th Mar 2010, 13:53 -
Error creating VCD
By maruz in forum ffmpegX general discussionReplies: 4Last Post: 17th Oct 2009, 06:42 -
C# program always crash when creating Windows Media Encoder object
By George2 in forum Newbie / General discussionsReplies: 7Last Post: 9th May 2009, 05:46 -
creating thumbnails for a real media file
By liddu in forum Newbie / General discussionsReplies: 1Last Post: 9th Sep 2007, 17:10
