Hi,
I've always been confused by something. This site lists bit rates at which various DVD players are known to work. For example, my Panasonic RV-31K is listed at 2500kbit/s.
Does this bit rate mean just the video rate or does it include the audio that's multiplexed in?
Also, if you're encoding with CCE, there are Max and MaxAvg parameters. Do both settings have to remain below your DVD player's limit in order to work? Or maybe just the MaxAvg since occasional high bitrate spikes wouldn't last long enough to overflow the player's buffer.
Any thoughts? Thanks!
Jeff
Results 1 to 1 of 1
Should i put average bitrate or max bitrate in 2pass encoding mode?
By tendra in forum Video ConversionReplies: 28Last Post: 11th Nov 2011, 07:38 -
tv player at reasonable price that can play hi bitrate xvid/avi?
By extent in forum Newbie / General discussionsReplies: 0Last Post: 25th Feb 2010, 08:42 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 18:17 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 7th Nov 2008, 23:54 -
How low can I make xvid bitrate and still play on new DVD player?
By jimdagys in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 21:07
