I hope there is an easy way around this. I recently bought a few DVD's from asia which dont have trailers or Comentary files. (the appear in the main menu, but dont load)
I was wondering if there is an easy way to locate these files from the VIDEO_TS Structure to safe space. I dont to be able to backup DVD's larger than 4.7 but dont want to reEncode.
I looked around in the forum but didn't see anything. Any help would be appreciated.
Are you talking about trying to find them on the Asian dvd's or ripping your own dvd's?Originally Posted by hector2028
If you are talking about the Asian disks then they probably have been reencoded and stripped of all that stuff already (No way to find them.)
If you are talking about backing-up your own disks then you can use IFOEDIT to strip any streams. This method doesn't always reduce the size enough to fit it on one dvd-r (So you may have to reencode.)
Check here in "The Guides" section on how to use IFOEDIT:
www.doom9.org
How to author & burn a DVD from VOB trailers/files
By Baldrick in forum User guidesReplies: 62Last Post: 30th Sep 2011, 06:39 -
Removing Trailers from a 4.9GB DVD to fit in a 4.7 GB DVD+R
By rotchild in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2009, 19:20 -
cant get audio comentary off of some dvds with clonedvd2
By pigtails2 in forum DVD RippingReplies: 0Last Post: 22nd Feb 2008, 17:55 -
viewing mpeg2 (vob) timeline & removing commercials
By rancid in forum EditingReplies: 11Last Post: 30th Jan 2008, 05:11 -
Changing/Removing an audio track from a .vob
By TheWeasel in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jul 2007, 09:31
