  1. I used TMPGE to encode a portion of
    an .avi (I split the file as it was too big
    and just wanted to test the conversion result).
    It seems that every now and then the movie seen
    as .mpg sort of slows down and almost stops for like a
    split second every 40/50 frames. Did I do something wrong
    when converting from .avi to .mpg or does
    this happen when you split an .avi (using VirtualDub)?
    Thanks!
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    it may just be your system (lag in hard drive most likly or in decoding)
