i have just gotten into using vcd and my dvd player(phillips dvd825) supports vcd, I purchased stephen kings the shinning on vcd, and when i play it on my player it is in black and white, on my pc through windvd2000 playback is color,
the philips dvd player does not have a very good setup screen and i have not found any help on adjusting the video input.
thanks
It sounds like your using an ntsc tv (America, Japan and others) and are trying to play a pal vcd. When you do this you lose color. I'm not familiar with your dvd player but if it has a pal or multi mode then enable it and it should play fine. If it doesnt then you will need to convert the vcd to ntsc and re-burn. To do this copy the dat file to your hard drive, its in the mpegav folder on the disk. convert the dat to mpg with vcdgear (www.vcdgear.org) and load it in TMPGenc with the ntsc vcd template loaded and encode.
Also though this probably isnt the problem, try unplugging all other inputs from your tv except your dvd player. Sometimes this can cause loss of color. -
Of course, the inverse applies too. If you try to play an NTSC on a PAL TV you'll also get monochrome playback. Ah, the joys of international trade and varying standards......
converted AVI to VCD, but playback is too fast
By LWC in forum Authoring (VCD/SVCD)Replies: 4Last Post: 21st Nov 2008, 22:55 -
Black/White blocks on DVD playback/rip
By babyshambler in forum Newbie / General discussionsReplies: 2Last Post: 25th Oct 2008, 15:41 -
Need to convert VCD (352x288) into DVD and crop black bars off
By smashingly in forum MacReplies: 8Last Post: 10th Aug 2008, 06:12 -
Playback in black and white
By verm1n in forum Portable VideoReplies: 3Last Post: 29th Dec 2007, 05:54 -
consolidate vcd files with Nero Vision, but problem with playback
By slh888 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2007, 18:36
