Results 1 to 12 of 12
  1. hi guys
    i have a quick time file and i want to convert it to mpeg
    mov > mpg
    can any one help?
    thx alot
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    u can go this route also http://www.vcdhelp.com/mov2avi.htm
  3. thx for replying BJ_M
    i did everything in the lesson
    but the movie is too small and it appears in the in the up left corner
    see what i mean in the pic
    http://www.webpost.net/tt/tt123/movie.jpg
    i tried to change the Width and Height but nothing happened
    and thx again ^^
  4. hello
    i uploaded the file
    http://www.geocities.com/torutoby/sahara.mov
    (right click and save target as)
    can any body see whats the problem or try to convert it to AVI format and upload it again?
    thx alot
  5. Член BJ_M's Avatar
    Jul 2002
    Canada
    its corrupted - did you flatten it ?
  6. what do u mean corrupted i can still play it with Qucik Time Player
    i didnot do any thing to the file ...
    what do i have to do now?
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    well i couldnt play it ... maybe it didnt download correct ...
  8. Free Flying Soul liquid217's Avatar
    Feb 2002
    i just tried converting to vcd mpeg with tmpgenc and it worked flawlessly.
    www.vcdhelp.com/tmpgenc.htm
    make sure that you have installed the qtreader plugin for tmpgenc
    http://www.geocities.com/SiliconValley/4942/svcd.html
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    i converted it to mpeg1 1500 bit rate and mpeg2 2500 bit rate and no problems ... i re-downloaded it ok this time ..
    i also converted your 15fps to 29.97 and letter boxed for overscan ..
    here is your mpeg1 streaming
    http://www.simex-iwerks.com/test_oo/sahara_mpeg1.m1v
  10. When I convert a MOV file to MPG with TMPGENC I get no sound.
  11. Thanks guys you really helped me ALOT
    i finally did it ^^
    vcdguy1:
    No audio in the AVI File:
    Some Quick Time Movies have audio copy protection. A solution for it to download the application Total Recorder 3.0+
    http://download.cnet.com/downloads/0-1896426-100-4798087.html?tag=st.dl.10001-103-1.lst-7-1.4798087
    . After starting this application you must press the recording button and start your Quick Time Movie. Total Recorder will only record the sound that come from the Quick Time Movie. After recording, you have to save it as wav and multiplex it for example with TMPGEnc.
    i copied that from this page :
