  1. Hi there,
    I'm just struggling my way through DVD2SVCD, and noticed that while encoding the status line of TMPGenc shows 29.97 fps, while the DVD definitely PAL and as such 25 fps.
    I did not find any framerate-related setting in DVD2SVCD to correct this.
    Any hints? Is DVD2SVCD NTSC-only?
    Thx,
    Lowlander/2
  2. Can't help much with the answer, but I've encoded half a dozen PAL DVD's with DVD2SVCD without any problems, so it's definately not just NTSC !
    Panther
    All say Grrrrrrrrrr......................
  3. DVD2SVCD does both NTSC and PAL. Try checking "NTSC to PAL" in the "Conversion" tab to force PAL.
    -LeeBear
