Results 1 to 10 of 10
  1. I am using TMPGEnc ver 2.5 (full)
    I used DVD2AVI ver 1.74 to create the d2v file
    So I try to load the d2v file, and then TMPGEnc freezes up and says there is an error created in DVD2AVI.VFP
    I did put all the DVD2AVI files in TMPGEnc folder and it will still not load (it does recognize my wav file)
    Any help would be much appreciated...thanks!!!
    the best there is
    was
    and ever will be
    Aug 2002
    England
    hi
    Just wondering why u put them in TMPEnc folder????
    Make sure that after u start the process you dont move any files cos they wont be found later in the process.
    Just create a new folder called DVD or something. Save all the files you create to that directory.
    It should open fine.
    Fozzee
  3. Originally Posted by Fozzee
    That is where my problem lies. It should open fine, but it doesn't.
    the best there is
    was
    and ever will be
    Aug 2002
    England
    What ripper did u use?
    And what version of TMPEnc are u using?
    Fozz
  5. Originally Posted by Fozzee
    Fozz
    It says in my original post.
    the best there is
    was
    and ever will be
    Aug 2002
    England
    Ermmm no it doesn't!!
    TMPGenc version 5 comes in various builds.
    And DVD2AVI is not a ripper its a frame server.
    If u want help I suggest you give a bit more detail about how your going about this.
    Fozz
  7. TMPGEnc 2.5
    and
    Smart Ripper
    If anybody has had similar problems, please help...
    thanks
    the best there is
    was
    and ever will be
    Aug 2002
    England
    Is the first time you've done this??
    Has you had it working properly b4?
    Fozzee
    Feb 2001
    Berlin, Germany
    checklist
    dvd2avi.vfp is in the same directory like dvd2avi.exe
    TMPGEnc.vfp is in the same directory like TMPGEnc.exe
    check TMPGEnc vfp is registered to VFAPI (TMPG>option)
    check VFAPI plugin (dvd2avi>help)
    TMPG> option> enviromental setting> VFAPI> check dvd2avi project file reader and/or select a higher priority.
    Do not delete the .vob files. Do not move the .vob and / or .d2v unless you want to edit the .d2v manually.
    Also try to use the latest stable version of dvd2avi, that is 1.76.
  10. OK, cool it's working now.
    Is there anything I can do if it says streaming error? (This occured at 61%)
    ThanKs~!
    the best there is
    was
    and ever will be
