I get this message when trying to convert asf>mpeg in tmpgenc
how do I get around this
Results 1 to 9 of 9
i had the same problems, it just means that u havn't extract all the pack, u need to extract all the folders and then try again
please user our search engine in this forum
and also www.vcdhelp.com/tmpgenc.htm#problems
I have downloaded nimo codec pack + divx 3.11, 4. &5
increased priority in enviromental settings -> 2 still get the same message
can't load p3 package dll
tried to open in virtualdub 1.3 couldn't locate decompressor for format wmv2 unknown
tried to convert from asf -> avi in eo video after about 25 minutes of file conversion I get file must be corrupted freezes up
please help -
One thing at a time !!!!!Originally Posted by scaff1
You started off with one problem, and have moved on to several others !
First of all you need to download TMPGEnc zip file and unpack it correctly. In wizip right click zip file and select extract to c:\TMPGEnc etc
http://www.tmpgenc.net/
Inside that folder will be the P3 dll, and you should also have a template folder. If you do this then your first problem should be fixed.
Next is you have a ASF, some systems wont be able to load those into Vdub 1.3C but it should still load into TMPGEnc and convert (If its not faulty) else see my post on WMV/ASF conversion with GraphEdit
Sounds like you have a corrupt ASF -
Do not run Tmpgenc from a shortcut. Run it directly from the program list or program file and it should load up fine.
I managed to get the file to load up in tmpg by starting the program from the program list
However it took about 1 hr to process 25 seconds of the file before
freezing up
When I try to set the time frame start & finish, this freezes the program also
My orriginal problem is to try to get this downloaded concert to play on my standalone dvd player which is vcd,mp3,cdr,cdrw compatible
Virtualdub Error Message - Failed to load FFmpeg.dll
By SOSmkII in forum Video ConversionReplies: 5Last Post: 6th Feb 2012, 08:14 -
Need aacenc32.dll & aac.dll for be light
By tofuguy in forum AudioReplies: 5Last Post: 30th Oct 2011, 19:58 -
Computer keeps trying to load some weird ntload.dll file
By jyeh74 in forum ComputerReplies: 40Last Post: 28th Dec 2009, 09:41 -
MeGui -> Unable to locate libsndfile-1.dll and FFTW3.DLL
By whatever911 in forum Video ConversionReplies: 0Last Post: 21st Feb 2009, 15:34 -
AutoMKV problem, warpsharp.dll failed to load
By filanwizard in forum DVD RippingReplies: 2Last Post: 21st Aug 2007, 09:32
