  1. How do I check if I have a codec missing if I don't have vdub??
  2. you should just download vdub
    You do need it to convert from avi to mpeg
    why do you ask this? are you trying to play a movie and the player is telling you that you don't have the right codec
    Hope this helps
    VCD4ME
    We were all NEWBIES once and the only stupid question is the one that's not asked?
  3. I have created an avi from Premiere using Microsoft dv avi. For some reason I can't load it into tmpgenc 2.57. I figure I musn't have the right codec. Even though I don't really understand what that means!
    Will install vdub and post a list of my codecs.
  4. When I tried to open it in vdub I got the following:-
    Couldn't locate decompressor for format 'dvsd' (unknown).
    VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. Directshow codecs, such as those used by Windows Media Player, are not suitable.
    Any ideas?
    Thanks,
    Kaisha
