ok, I'm a newbie to this conversion thing and attempted by using EZCD Creator 5.0 to convert an .avi movie to vcd format. After I burn it, I pop it in my dvd/vcd player and all it says it no disc. For some reason, it won't accept what I have done. Are there any othr steps to this or what should I do? Thanks in advance.
When using EZ CD Creator the movie files must be in mpg you can convert them to mpg using TMPGec or just use Nero it accepts avi files
sorry about that, i was meaning mpeg on this. I tried the mpeg corrector, then tried to burn it using nero burner with no luck yet. I thought it was because I had no autoplay, so added that and no result still. The list states that my vcd player (Samsung DVD-M101) can view regular cd-rs in vcd format. I'm including all the steps I used to create this CD. Mpeg video checked by mpeg corrector; tested it with nero, burned it with nero. Pop it in my dvd player, states no CD. I have wasted 6 cdr's on this now and about to give this up. If anyone could give me the steps they use to convert it in detail, it would be greatly appreciated. Yes I checked the FAQ and all over this forum. Thanks in advance.
double post, sorry
<font size=-1>[ This Message was edited by: snafufx on 2001-08-15 09:25:59 ]</font> -
Obtain TEMPEnc from the TOOLS section of this forum.
Load your AVI and LOAD the appropriate VCD template for your region.
Click the START button.
Burn your MPEG using EZCD Creator or NERO, but try burning it on a CDRW. Important - do NOT format the CDRW in Diirect CD. Just use it as it comes out of the box.
See what happens.
AVI to VCD
By Slip Kid in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 00:40 -
avi to vcd
By cornick in forum Video ConversionReplies: 4Last Post: 11th Aug 2008, 20:12 -
AVI to VCD
By northy44 in forum Authoring (VCD/SVCD)Replies: 4Last Post: 6th Dec 2007, 06:27 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
