In TMPG audio encoding there is channels mode there is dual channels does this give you Surround sound with Dolby Dolby or DTS 5.1? And what does Joint-Stereo mean? thanks
Hi thank you but what encode can I use to get the 5.1 sound and after I encode it will TMPG mix it back together so I can make my VOB files. Thanks!!!
for a dolby 5:1 encoder you will need something like sf soft encode , the encoder that comes with scenarist or digigram or Nuendo w/ plug in ...
then you will need a authoring program for dvd that suport 5:1 - namely scenarist or maestro
no audio on playback tmpg
By devdev in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2011, 12:05 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 19:53 -
DVD authoring and encoding on TMPG and Ulead
By bellyting in forum Newbie / General discussionsReplies: 4Last Post: 29th Jun 2007, 16:53
