According to all of the guides I have read, one of the first major steps before encoding should be to use virtualdub to scan for bad frames in the divx file. My question is how many bad frames are to many bad frames? Also, what does it mean when there are something like 350 good but undecodable frames. Furthermore, is there some way to figure out just where these bad frames are to determine if they are saved out if it will be a problem. Thanks for any help anyone may be able to provide.
Results 1 to 1 of 1
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 18:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 09:15 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 16:00 -
.avi file cannot be repaired - need to remove bad/corrupt frames
By realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 04:39
