I had installed version 2.57 on my second machine (it had worked well on the identical files I have encoded on my first machine where I have an XTasy Everything and Sony DVD recorder). I could not load a MPEG2 file into the Wizard, although I could in the MPEG Tools section.
I then removed 2.57 and loaded version 2.56 Plus. Now I can open the files in all the windows, but the frame count is extremely large (604,392,198 frames for any file so far). The previews in the Source Range will not actually run now, so editing is impossible.
I had installed Power DVD 4 Demo, WinDVD, and WinDVR to try the MPEG codecs when I had the 2.57 version installed.
Can you not go backward to an earlier version?
There is no registry entries that I can find that might be interfering.
does anyone have a suggestion?
Results 1 to 1 of 1
DVDStyler - please advise on menu frame count/hardware compatibility
By dogcatcher in forum Authoring (DVD)Replies: 9Last Post: 15th Dec 2011, 02:48 -
Frame count display in Media Player Classic? Or something else?
By Hoser Rob in forum Software PlayingReplies: 2Last Post: 10th Apr 2011, 10:59 -
Different Frame Count When Demuxed
By sambat in forum EditingReplies: 0Last Post: 10th Oct 2009, 18:17 -
Incorrect video duration/frame count in MKV/AVC
By crashbang in forum Video ConversionReplies: 2Last Post: 13th Oct 2008, 16:44 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
