here's the scoop, i have a:
p3 800
60gig free partitioned into half
384mb ram
sblive value
64mb gforce2 mx400 video card
tyan trynity 400 motherboard
wintv go
my problem is this when i start to caputure with avi_io i always get this error, SORRY NO MORE I/O BUFFERS PLEASE REDUCE DATAT RATE, i also have stuff on my other partition on the 60 gig, any suggestions?
aslo is there any way to capture higher than 320x240 using WDM drivers?
I think you're trying to capture at too high a resolution. Here's what I did:Originally Posted by maxone
1] Trashed the supplied drivers in favor of the btwincap driver (I have a wintv radio card)
2] Trashed avi_io in favor of virtualdub
I can cap at 400x480 with huffyuv compression on my celeron 366. BUT you have to disable the overlay for anything over 320x240 AND your supplied wintv tuner app probably won't work any more. -
Your best bet will be,(as the previous post mentioned),is to turn off Overlay, but I also suggest you even turn off the "preview" mode as well.
PCIe/USB AVI Capture device with SVideo and fully functioning Win 7 drivers
By Spektre in forum Capturing and VCRReplies: 3Last Post: 23rd Aug 2011, 19:34 -
DirectShow and Drivers--multiple instances of the same capture card
By Austin Covello in forum Newbie / General discussionsReplies: 0Last Post: 7th Feb 2011, 10:43 -
Help with drivers? Initialization in my Capture Card!1
By hkseo100 in forum Capturing and VCRReplies: 0Last Post: 7th May 2008, 19:41 -
drivers
By Mr anderson in forum ComputerReplies: 2Last Post: 29th May 2007, 04:36 -
To Capture or... To wait for drivers?
By Yeah in forum Capturing and VCRReplies: 3Last Post: 12th May 2007, 17:31
