Hi,
Recently i'm tried to capture video using VirtDub but there but there is no video image was capture. Anyone can help me????
Can you give us some more information? What speed processor are you using? What are you capturing from - cable, video input, FireWire? What kind of compression are you using on the video?
Animation and geeky reviews and podcasts at
Cartoon Geeks (http://www.cartoongeeks.com) -
I'm using P3 933Mhz, capture using firewire with my mini DV Panasonic NS 30
I have the same problem, Im using my mini DV JVC and I don't get any picture or sound. Im using a fire wire, I have 4.8 processor with 512 ram and 100 gig hard drive. I can capture with other programs but not with VD
Just looking for the right button to push! -
Select File->Set Capture File and configure where you want to save your avi. Then Select Capture->Capture video. Hit Begin when you want to capture.
I know that much.....its after that when nothing happens, all I get is a gray screen with dotes. Im running windows XP if that has anything to do with it.
Thanks -
vdub doesn't support firewire cards, only analog like mine. I know that for a fact coz I tried it with my cousin's computer who has a firewire card and I used vdub to capture but it didn't work. Use other capture programs like adobe premiere 6, vegas video, pinnacle dv studio , etc.
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 01:02 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18
