I've made a couple working vcds that have performed just fine in my dvd plaer. Lately I haven't been able to make a sompliant vcd and I must have wasted like 30 discs already. So I decide to redo one of my working vcds. I use the same exact files, I use the same exact programs, I urn it the same exact way, but it doesn't work this time. It reads no disc in the dvd player jsut like all my other faield vcds. Any ideas? Thanks for reading.
That's really a lot of coasters. I HATE coasters
What can i say?
1. Find a format you are comfortable with and stick with it. (VCD,SVCD/CVD, max bitrate? ...)
2. Get a DVD player that will play anything. (Hint: see DVD player compatibility list)
3. Stay within the boundary of your burner. (Writing Speed, Overburning, etc...) -
Did you change CD-R media?? or you aren't using CR-RW some players can't handle that either. Seems strange...
Good luck
Trouble capturing from VCR, completely stumped
By mikeveli20 in forum Capturing and VCRReplies: 12Last Post: 25th Oct 2009, 11:00 -
DivX -> AVI/MPEG - stumped!
By ouroboros10 in forum Video ConversionReplies: 4Last Post: 7th Apr 2009, 14:23 -
VHS to DVD to PC has me stumped! Cant import audio to my software...
By jojokaa in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2009, 10:58
