  1. I just installed the Codec and it said something about:
    "Don not install G4000 if you do not have G4000 card", o.k i get that and i do have a Graphic 4 card but it also said somehing like:
    "Do not intall the Bisceup filter if you do not mind up-side down picture", or something like that. Question do i install that or not, is there anything else i shouldn't install.
    All i need Nimo is to convert avi. files to mpeg. files using Tmegn.
    Pls Help
  2. Member DJRumpy's Avatar
    Dallas, Texas
    When in doubt, answer no. If you find you need it later, you can always go back and install it.
