I have been using SpruceUp 1.0 for my authoring to do menus, etc. I just got a copy of Maestro but haven't played with it yet (I'm at work). But I was just curious if it has the 4:3 export problem that SpruceUp has, does it do 5-channel AC3 (when the source is 5-channel AC3 and\or 2 channel PCM) and what makes it better than SpruceUp. Thanks.
Scott.
well its about 20,000 x more expensive not that means a lot sometimes ...
Maestro and Scenarist are the two best authoring programs avaiable.
it does DTS , ac3 (5:1 yes) , pcm etc .. there are no exporting problems though export to what im not sure what you mean... it can do both wide screen and 4:3 and has a host of other features .... -
Yes, I just meant the problem where SpruceUp exports widescreen movies as 4:3 (well, simply labels them as such) and you have to use IFOEdit to fix it. Most of the tutorials assume you are using Maestro as the authoring tool so I thought I would give it a try. But I wanted to be able to keep AC3 and SpruceUp was one of the few to do that (and Maestro, too, from what you are telling me). Thanks.
A decent substitute for DVD Maestro
By Drakul in forum Authoring (DVD)Replies: 12Last Post: 8th Mar 2012, 21:11 -
DVD Maestro - Multiple assets, one VTS
By alfini in forum Authoring (DVD)Replies: 0Last Post: 10th Nov 2010, 01:32 -
[ INFO ] Maestro SBT 2.6.0.0 *does* support Unicode
By Midzuki in forum SubtitleReplies: 2Last Post: 15th Jun 2010, 20:25 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 03:22 -
Spruce ACX 5100 & Maestro
By zerohash in forum Capturing and VCRReplies: 0Last Post: 12th Sep 2007, 01:59
