    Aug 2002
    England
    Hi all!
    I have an SVCD which i would like to convert to AVI. I have tried to copy it onto my hard drive, but for some reason it won't let me. It had 15 seconds left to go, then came up saying cyclic error.
    Could anybody tell me why this is happening please?????
    Upstate NY
    Mabye the original was overburnt and your cd-rom is having a hard time reading it?
    Aug 2002
    England
    Me again!
    Had a look at size, and it said 797MB, so yeah, looks a bit big to me!
    Thanx anyway! 8)
    Aug 2002
    England
    Just out of curiosity, is there a way round this, or is there nothing i can do?
    Upstate NY
    Try in a diffren cd-rom, some are better about reading smaller pitch (80min) and overburnt disks.
  6. Member Gargoyle's Avatar
    Jul 2001
    Southern New Jersey, USA
    you can try to create an image file of the SVCD (.bin, .iso, etc.), then use Isobuster or CDMage to extract the MPG file from the image file to you hard drive - but if you CDRom is having trouble reading the disc, this probably won't work.
    BTW, can you play the entire clip from your CDRom?
    You can't fool me, I'm a moron!
