  1. I Cant convert mpeg's to vcd's. I set up on my TMPGEnc converter and whenever i hit strt it alwys tells me that my file cannot be created. Can someone tell me what i am doing wrong?...thanx
  2. TMPGEnc is for encoding AVI to MPG...
  3. if TMPGEnc is for converting avi to mpg..then wuts a good program for converting mpg to vcd?
  4. You do not need to convert your mpeg to vcd...as long as it is already a vcd compliant mpeg. That means that it is 352x240 mpeg1 1150 kbps and the audio is mpeg1 audio layer 2, 44.1 khz 224 kbps....to check this out use virtualdub. Open the mpeg file....then go down to file information.
    IF it is not compliant let me know,,and I will try to help.
    Nice to help someone else,,,,I had the same problem.
    Hope it helps
  5. Thanx for the help..if my mpeg is already vcd compliant can i go ahead and burn it with hp cd writer or will i have to use nero??
