i am using nero to burn my vcd's what should the encoding resolution
tab be set to. pal or ntsc.
I think that option only needs to be set when Nero needs to encode the video to MPG before burning. For instance, you want to create a VCD/SVCD but dragged in an AVI file.
Nevertheless, even when I'm burning a MPG I always set the encoding resolution to the encoding resolution used on the MPG. Just to be sure.
To determine which encoding resolution to use you need to check the source file. (AVI or MPG).
For VCD:
PAL = 352x288 at 25 frames per second.
NTSC = 352x240 at 29.97 frames per second.
For SVCD:
PAL = 480x576 at 25 frames per second.
NTSC = 480x480 at 29.97 frames per second.
Regards,
sP1D3r
Video Compilation
By redcapeman in forum EditingReplies: 4Last Post: 27th Dec 2010, 05:01 -
When Ripping Compilation CD's...
By Nitro89 in forum Off topicReplies: 3Last Post: 1st Nov 2009, 08:48 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 01:57 -
DVD compilation.
By Benhermies in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2008, 11:46 -
trying to create a compilation DVD and getting nowhere
By JasonWatkins in forum LinuxReplies: 2Last Post: 26th Oct 2007, 21:06
