Hi all.. I'm trying to rip Prince of Egypt with SmartRipper, but after I load the disc into my DVDROM and start SmartRipper, it says "No DVD Found". I never exprienced this problem with other movies.
So I try DVDDecrypter and it can detect the movie.
I also enabled the stream processing in DVDDecrypter but VobSub cannot make the subtitles (just for this movie).
How can this happen? Why smartripper can't detect the DVD?
thanks
hmmmm, not sure
you may want to tell the author.
but try installing an ASPI layer from http://www.adaptec.com first.DVD to VCD made eazy
http://www.eazyvcd.tk -
smartripper only says no dvd found if it's a game!
smartripper does fail - but can usually be got around by switching from auto or aspi to normal.
aspi is also necessary unless the dvd has no copy protection whatsoever.
Best playback software for ripped movies?
By Vrex in forum Software PlayingReplies: 3Last Post: 8th Feb 2009, 23:23 -
Can't watch ripped movies on Panasonic DVD-F87
By arbutler in forum DVD RippingReplies: 5Last Post: 13th Oct 2008, 19:40 -
Question on ripped movies playing in high-def.
By dimtim in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2008, 00:07 -
What is the best/easiest way to convert ripped movies keeping best quality?
By Emanef in forum DVD RippingReplies: 55Last Post: 25th Aug 2008, 12:07
