Hi guys,ive just joined this great forum to ask this question that is doing me head in!!
I have an avi clip which i want to convert using cce 2.64 and then author onto dvdr using ulead dvd workshop.
I have converted the avi but i mustnt have the settings correct in CCE because when i try to use it in Ulead it starts to completely reencode it all again...please help me before I do something dangerous to myself.....and i might just do it,,,i might..!!!...lol
cheers
Max
If you are using version 1.2, check the "do not convert compliant files" box on the last screen before you burn. If you are using version 1.0, it will not reencode if you choose DVD WS setting with a higher bitrate than you used in CCE (I think . . . . it might be the opposite, search the forum, the answer's here, or do a short test, don't rely on my answer for v 1.0). Note that your format must be compliant though (ie if you encode in CCE to 640 x 480, DVD WS will reencode no matter what because that size isn't a compliant DVD format)
That would cause it. You may have to resize your AVI file unless there's a way to specify the output size in CCE. I know there is if you're using the Premiere plugin, but I can't find the option in the standalone version of CCE.
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
How to Convert AVI to DVD + AC3 with CCE and AC3Machine
By ta2 in forum User guidesReplies: 40Last Post: 21st Jan 2010, 18:01 -
Ulead DVD MF6 takes over 11 hrs to convert?
By Hondamaker in forum Video ConversionReplies: 2Last Post: 20th Jan 2009, 15:20 -
AVI file(s) too large for DVDR
By sybarite in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 20:35 -
convert .mov to dvdr
By -mm- in forum Video ConversionReplies: 2Last Post: 25th Mar 2008, 13:35
