Tried successfully convert a .avi to mpeg, then burn into VCD.
However, there are some files, when trying to convert to mpeg, the wizard will have this,
"Make File size [93.99] % of CD. "
This makes my 20mins anime, to 70mins!!
Why is this so?
For the rest, it will remain at 20mins+, and the file size is 20++%.
Tried searching for options to change it, but it remains gray...
Anyone can help?
Problem Solved
When I used virtualdub to open the s/w, gave me error on the audio...
So I extracted the audio as wav, then used tmpgenc to convert.
Video n audio syn, and total size is 200mb+.
Finally, I can encode all my anime into VCD and watch...
Thanks for viewing.
Converting Anime DVDs to AVI (AutoGK)
By vangelon in forum DVD RippingReplies: 6Last Post: 18th Nov 2009, 03:25 -
Gotsent, sync problems MKV anime, dual audio and subs to xbox 360
By TheGlow in forum Video ConversionReplies: 2Last Post: 15th Apr 2009, 19:33 -
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 15:34 -
Anime DVD to X264 with Staxrip - is it worth using the 'anime' setting?
By Emanef in forum DVD RippingReplies: 2Last Post: 8th Nov 2008, 15:31 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54
