i ripped the dvd using dvdextractor .9...i checked the boxes for mpeg 2-video (m2v), Private (ac3, etc.), and merge selected items...i only ripped the main movie...the largest file of them all...i came up with three ac3 files and one m2v files, among others that ended with spc...when i tried to use mac3dec to change the ac3 files to aiff i got an error message and the mac3dec tried to fix the problem but failed...when i tried to change the m2v file to mpeg-1 using media cleaner 5 i got the job done in 1 or 2 seconds...something didn't work right...can you help?...are there certain preferences or settings that i need to check...if so, which ones...?
Be sure you have MPEG charger for cleaner and the newest mAC3dec. If it's not working with Cleaner 5 MPEG charger try using MPEG2encoder. http://www169.pair.com/lukifer/ for all shareware.
If you still have the same problems try ripping .vob's, tracks or chapters. Or uncheck "merge selected items" and check "macrovision disabled" in DVDextractor (I use 0.6 but 0.9 should be better).
This is all I can think of, so if it still doesn't work try the same settings with another DVD.
Mark,
The Netherlands
<font size=-1>[ This Message was edited by: markpith on 2001-07-03 09:22:51 ]</font>
best settings for ATI600USB in Catalyst Media Center
By Blitzkrieg in forum Capturing and VCRReplies: 6Last Post: 15th Apr 2012, 12:43 -
Media Player Classic - Home Cinema Settings Help
By ACiDxCHRiST in forum Newbie / General discussionsReplies: 5Last Post: 17th Sep 2011, 23:29 -
Looking for a guide for optimal settings for media on PC/Headphones
By Morcas in forum Software PlayingReplies: 0Last Post: 8th Feb 2011, 23:49 -
Cleaner XL Settings (MPEG2 Files)
By robbyp3 in forum Video ConversionReplies: 2Last Post: 23rd Feb 2009, 09:05 -
MS Media Player settings reversion problem
By Xylob the Destroyer in forum ComputerReplies: 0Last Post: 7th Jun 2008, 09:51
