    Portugal
    Hi,
    I´m using Ulead DVD Workshop to author my DVD with menus, motion menus and lots of stuf...
    I have the following bugs that i want to share with you guys:
    - When i insert chapters, i have a 1/2 sec pause between chapters when watching the movies on my standalone DVD player
    - Sometimes i have navigation problem when i have lots of menus
    - When i use motion Buttons, the menu wont work properly
    Does anybody knows about this problems ? or found other problems with this authoring software ?
    By the way, there is some other program good for authoring DVD with motion menus ?
    best regards
  2. First, if you are not using the trial version of DVDWS had you updated to version 1.2? I have not run into any of the problems you describe but could you supply more details?
    When you get the 1/2 second delay between chapters are you using 1 mpeg file and dividing it up into chapters or are you using a seperate mpeg file treating each title as a chapter? If you are using a seperate mpeg files for each for title you call a chapter there is a delay when switching between titles.
    Portugal
    I already have the 1,2 version...
    And i´m using just one mpeg file where i put some chapters...
    This 0,5 sec break between chapters seems to happen in every job i do with WS ... Theres some king of configuration possible to do with the chapters ?
    thanks a lot for the feedback
  4. Sorry if this is too far off topic, but how do you add chapters to 1mpg file in DVD Workshop. I can't seem add the chapaters.
    Thanks.
