I use TMPGEnc frequently and never experienced the problem below.
As source, I use a 25 fps .avi file. However the frame rate in the
"Source range" window of TMPGEnc shows 30 fps if the "DirectShow File
Multimedia Reader" priority is set to 1 in the "Enviromental settings"
(VFAPI plug-in). With this setting, I get jerks in the MPEG-2 file in
scenes moving quickly.
When this filter's priority is set to 0 or -1 (default), the jerks are
gone, but there is no sound (MP3 inside a DivX) either.
Two possibilities ...
1. How can I get rid of the jerks with this filter's priority set to 1?
2. How can I get sound while this filter's priority is left at -1?
Many thanks!
Results 1 to 1 of 1
AVS to psudo-AVI via VFAPI (1.05), in a BATCH FILE?
By RogerTango in forum Video ConversionReplies: 1Last Post: 6th May 2012, 00:49 -
DirectShow Error: File (path) does not have a video stream
By kstraynor in forum Video ConversionReplies: 1Last Post: 23rd May 2011, 16:44 -
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 14:46 -
VFAPI Reader Batch convert?
By Totta in forum Video ConversionReplies: 0Last Post: 20th Sep 2010, 11:44 -
Unexpected issue with VFAPI Reader
By NotSoEasy in forum DVD RippingReplies: 6Last Post: 8th Feb 2008, 04:29
