using movie factory to make SVCD well actually XSVCD and have multiplexed the video with 2 audio tracks and when burning in Nero works fine however when trying to burn in Ulead, it only gives me the last audio track ( well the second one out of the two) is there a way to fix this or is it a problem with the program, i dont see why it should do this, because the ability to have 2 audio tracks is an SVCD standard??
j_c
you may need a higher end dvd authoring program to set up two audio tracks. Svcd's can handle two audios, no prob.
Some appz like spruceup, dvdit, maestro, etc....would probably allow two audio, subs, etc... -
I did have probleme with it .I did change setting and some path on it and everthing work perfect .tring to find the patch for it .
Ulead DVD Movie Factory 6 Plus
By orientaldragon in forum Newbie / General discussionsReplies: 8Last Post: 2nd Apr 2011, 08:48 -
By Ragamuffin in forum Authoring (DVD)Replies: 3Last Post: 6th Oct 2009, 12:22 -
Ulead DVD Movie Factory...
By mmitchell_houston in forum Authoring (VCD/SVCD)Replies: 225Last Post: 23rd Oct 2007, 10:59 -
By koberulz in forum Newbie / General discussionsReplies: 10Last Post: 26th Jun 2007, 07:14 -
Ulead DVD Movie Factory 5 Plus Help
By sootylfc in forum Authoring (DVD)Replies: 3Last Post: 21st May 2007, 18:20
