I just downloaded a 3 cd svcd, when I try to play it on my standalone dvd the image doesn't stop shaking. When I play it on my pc with powerdvd, everything is perfect. I copied the videofile of the svcd to my hd and wrote an svcd again with it. Same result. When I now convert this file to divx and then convert it to vcd it works like a charm but ofcourse with quality loss. Does someone know how to resolve this prob so I can keep the svcd quality ?
For your info, my player has no prob with other svcd's or vcd's so I don't think that's the problem .
Thx guys
After you got the file from disc to your hdd. I would suggest you to try to multiplex with MPEG2-SuperVideoCD(VBR) first then author back to SVCD again. It might work.
Well I found out that even with multiplexing the problem wouldn't go away, so what I did was copy the avseq01.mpg file to hd, than let TMPGenc use this file as source to create an svcd with cbr and everything works out fine, no more quality loss only disadvantage is that it takes up to 2 hours/cd and the movie consists of 3 cd's so that's a 6 hour job.
Thx for the help anyway m8
Grts
SetteCop
SVCD 2 DVD Not Working - Cant Add VTS or Click Convert
By rytech in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Feb 2010, 04:55 -
my panasonic standalone dvd can't play pal dvds...but can play pal svcd's
By stoico1 in forum Newbie / General discussionsReplies: 0Last Post: 9th Sep 2009, 17:46 -
DVD With standalone Menu HELP !
By rockonvidtrade in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2008, 13:51 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 19:23 -
Menu buttons not working in standalone players
By pixiemyela in forum Authoring (DVD)Replies: 1Last Post: 5th Oct 2007, 18:20
