I got DVDx and I open the IFO from a DVD(NTSC) then it opens up in the player and seems ok. But when I hit encode it says MMX may not work properly on AMD.Do yu want to continue. I hit yes then it says : MEPGEnc Unable to open program file none. Whats up with this what did I do wrong?
Results 1 to 13 of 13
In DVDx choose Settind then Output Settings. When the window opens look for Calculation (4th item in left column) set this to MMX+3DNow for AMD processors. Try this it works with my T-Bird.
What is the quality of the encoding from DVDx?
I got the same error klay51 did, but I didn't mention it. I figure if the software doesnt work or appear to work the first time, screw it. I like to try out new things, but it really has to wow me right away or I just go back to TMPGEnc. -
The AMD part of his question may have fooled me as I set mine to just MMX and got the first error but not the second one about unable to open program file. Did you both miss the select output button in the lower right of DVDx?.
For more info see Sefy's guide at:
http://www.vcdhelp.com/dvdx.htm
As far as quality, I have not run a full movie yet myself just some test clips that appear very good. -
Well I tried with diff. settings and when it gets to about 4% it says Mped2DEC:Too Much Sample change detect progressive 24hz or framerate. this is makin me mad
DVDx v1.1 currently has some bugs regarding NTSC discs, i'm in talks with the creator of the program to beta test it since I both have NTSC and PAL discs, and he agreed, so i'm waiting for the DVDx v1.2, as he said he fixed the NTSC problem there.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I've had no errors but I have tried DVDx 1.1 on a few short PAL DVD clips and I find the resulting mpg file very poor in quality. Played around with a few of the settings and things only get worse.
I'll be staying with TMPGEnc for VCD's until I can see a vast improvement.
As i've only came across DVDx 1.1 yesterday, I only managed to try it on two movies, one PAL and one NTSC, and as for quality, I didn't notice too much diffrence between it and TMPGEnc in VCD, actually it is the only one that let me do "Lady and the Tramp 2" without Sync problems, even DVD2AVI created a small sync that went big till the end of the movie, so this program defenetly has potential!
Best Regards,
Sefy Levy,
Hey Sefy..when can we expect a new version? I know you arnt the creator but I knw you also talked to him.
Well, since the author did not contact me yet again with the Beta, I can't tell you anything yet, as soon as I have any information, i'll post it right here
Best Regards,
Sefy Levy,
DVDX 1.2 is out here is the link
http://www.inet.hr/~mirebic/dvdx-guide/Index.htm
Yay While it seems likeits gonna take A LONG time i seems to be working with NTSC disc! An I didnt expect such and UPDTATED release this soon. It has more featres. You can check to see if it is compliant BEFORE you encode. Oh and if u are doing NTSC watch out the deafault resolution is PAL so you hav to change it. This threw me off at first and I thought it still didnt work. ut hey looks like itdoes. Bravo Doom9. So yes DVDx IS all it's cracked up to be(Well I think I havent actually seen the quality so...)
Well, that would explain why he didn't contact me back, oh well, you win some you lose some, he even made a better guide there
Best Regards,
Sefy Levy,
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 22:57 -
New DVDx 2.20 release is out!
By Jim@labDV.com in forum Latest Video NewsReplies: 3Last Post: 16th Jun 2009, 01:53 -
New DVDx InfoTool is out
By Jim@labDV.com in forum Latest Video NewsReplies: 0Last Post: 22nd Dec 2007, 08:32 -
Error in DVDx?
By php111 in forum Newbie / General discussionsReplies: 1Last Post: 6th Oct 2007, 14:17 -
MTR can't read DVD... READ ERROR: Can't Open IFO.
By strathq in forum MacReplies: 16Last Post: 16th Jun 2007, 23:04
