I just bought the Sopranos Season 3 DVDs and was ripping them so I would have a copy at my lake house. Everything went fine until I was ripping the second episode on the 4th disc. Smart Ripper froze at 42%. I also tried using DVD Decryptor and had the same problem. I thought maybe the DVD was defective so I exchanged it for a new set and it still does it.
I've never had any problems with ripping in the past. Does anyone know what might be wrong? Any ideas would be greatly appreciated.
My mistake. The ripping process doesn't freeze, it just gets REALLY SLOOOOOW. The ripping speed drops from about 8x down to about 0.1x.
I've had that happen with a few discs with Smartripper. I used a different DVD drive and it went away. Also, you can try using dvd decrypter or some other program and see if that helps.
try cladDVD XP
or even my software as it used the same ripper "vStrip"DVD to VCD made eazy
http://www.eazyvcd.tk
AVCHD playback problems on PS3, black screen at midway point
By mikeveli20 in forum Authoring (Blu-ray)Replies: 4Last Post: 28th Mar 2011, 13:46 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
AVI Freezes up
By surffx in forum Newbie / General discussionsReplies: 9Last Post: 12th Mar 2010, 06:49 -
my computer freezes
By bits27 in forum MediaReplies: 20Last Post: 9th Sep 2009, 01:35 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 10:22
