can't seem to find it.
actually there is one, take a look here
http://www.vcdhelp.com/dvdtovcdflask.htm -
I've only done two subbed movies- the first one was a DVD rip using DVD2SCVD (SVCD with selectable subtitles); I just enabled the Subtitle option in the "Subtitles" tab.
The second was a Divx .AVI file (for a SVCD with permanent subtitles); for that one I loaded the .AVI file into VirtualDub, re-sized and used the subtitle filter to load the subtitle file, then frameserved to CCE.
More info- see my post about VCDEasy and subtitles:
http://www.vcdhelp.com/forum/viewtopic.php?t=105597&highlight=You can't fool me, I'm a moron!
Subtitle Processor - anyone know of guide to translate?
By dweeb52 in forum SubtitleReplies: 6Last Post: 15th Jan 2016, 09:27 -
Vertiggo's Subtitle Guide (if all you have is mkvmerge)
By vertigoanduminas in forum SubtitleReplies: 1Last Post: 7th Sep 2011, 22:15 -
Convert subtitle of .idx/.sub to .sup for AVCHD, Remove embedded subtitle.
By wisitch in forum SubtitleReplies: 2Last Post: 18th Jun 2010, 11:25 -
Conver MKV with ENG audio/subtitle to AVCHD or Blu-ray with subtitle help?
By teaberry in forum Video ConversionReplies: 2Last Post: 3rd May 2010, 17:03 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34
