  1. I have tried to rip a DVD in OSeX and Extractor and i get the same results, my comp crashes. At first i thought it was only doing this to a certain DVD but i have tried several w/ the same result. I don't know if its my DVD drive or what. I have ripped DVD's before. I NEED help. Thanks
    My Specs:
    iMac DV Special Edition G3 400 mhz
    Mac OSX 10.1.5
    less than jake, wooo hooo!!!!!
  2. Member milatchi's Avatar
    Aug 2002
    U.S. Outpost 31, Antarctica
    Are you getting Kernel Panic and having to restart the computer?
    Or is it just OSeX crashing?
    I have noticed that for some reason OSeX does not want to quit when I choose quit, or do the good ole' "apple Q"
    And I usually have to Force Quit it.
    "First god damn week of winter." --R.J. MacReady
  3. i am getting a Kernel Panic. What is this and how do i fix it?
  4. any help on this problem that is the Kernel Panic?
    Jun 2001
    Silver Spring, MD USA
    When I was getting a lot of kernel panics, I eventually reinstalled OS X, did all the software updates, then loaded applications. That solved the problem.
    Yesterday I had my first kernel panic on my new TiBook. For that I just needed to shut the computer down. For safety's sake I rebooted into OS X two more times without running any apps. Seems fine now.
