when i start up mistro it says no encoders found so i can do real time playback so what are some encoders that work with this software i have cinama craft encoders but it stii says that anny help![]()
u got almost 20,000 worth of software and i guess no help manuals with it ..
anyway it requires cinemaster hardware or software codec for "REALTIME" video playback to happen ... which is what you are seeing
cinemaster is the only one that works and comes with Maestro (its on the CD) .. also cinemaster 2000 works fine also if you are using win2k instead of Nt4 ..
any refrence to Maestro 's "encoder" refers to the spruce hardware 3000 encoder. which is not required for operation. -
thanks for the headsup BJ_M looking into the solution i just grab my cd hehehe
Quick DVD LAB Pro question
By sterankin in forum Authoring (DVD)Replies: 5Last Post: 12th Aug 2010, 05:13 -
TMPGEnc DVD Author 3 - Quick Question on a Setting
By heyjjjaded in forum Authoring (DVD)Replies: 4Last Post: 5th May 2008, 16:04 -
TMPGEnc DVD Author - Quick Slideshow Question
By heyjjjaded in forum Authoring (DVD)Replies: 2Last Post: 4th Mar 2008, 06:13 -
Hi havent done much dvd burning in awhile and had quick question
By pitten247 in forum Newbie / General discussionsReplies: 5Last Post: 15th Jan 2008, 20:10 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38
