I just ripped harry potter with DVDx in svcd and burnt using Nero 5.5.5. The movie seems stretched or squashed when played on my Apex dvd player. The same when played on my PC.
Any help would be appreciated
You need to set input compression to "full - 4x3 and 16x9 input.
That should do it. -
also, check that you have set the video sorce to the correct frame typr (Interlaces or Progressave) this does make a difference to resizeing, al make sure you are useing the correct aspect ratio for the sorce, NTSC or PAL, these also bake a big difference in resizeing.
DVD to VCD made eazy
http://www.eazyvcd.tk
Squashed ffmpegx Flash Video in iWeb
By IrishP in forum ffmpegX general discussionReplies: 10Last Post: 20th Jun 2011, 08:32 -
Fixing horizontally stretched video
By robjv1 in forum EditingReplies: 7Last Post: 10th Sep 2010, 02:49 -
Streaming Video with vista 64bit Squashed! HELP!!!!!!!!!!!!
By dking in forum Video Streaming DownloadingReplies: 1Last Post: 21st Jul 2009, 13:17 -
Why is my converted video stretched beyond the viewing area on my TV?
By Clare in forum Video ConversionReplies: 2Last Post: 6th Oct 2007, 13:41 -
Help with rendering time-stretched video
By architectus in forum EditingReplies: 1Last Post: 26th Jul 2007, 14:34
