Synopsis:
Mpeg-1 file, non standard size - wanted to do a resize to NTSC format. Mpeg running time: ~85 minutes
Original Mpeg had a bitrate of about 850 kpbs(yes, it was lower than normal)
I decided for the sake of space to make a 985 kbps and fit it on one CD, which the XVCD calculator said was kosher for a file that size
Encoder: Tmpenc 12i, 128 bit audio, 985 kbps
Resulting mpg - over 950 megs. CRAZY!
Even Crazier:
I cut the mpeg in 2, thinking i would need to use 2 cds - SURPRIZE - the 2 parts were under 800 megs combined!
Where the hell did the 150 megs go? I was even able to burn the 2 mpegs onto a vcd with 2 tracks, but there is annyoing pause in the middle where the cut is when the DVD player skips tracks.
How can i resolve this? Pweeeze help!
Man how long did the encoding of it take?
Mine took 72 hourswww.vcdhelp.com/phpBB/viewtopic.php?topic=54826&forum=3&0Obviously i didn't wait...
But my move of 247MB is in
*.asf format and
2 hour total length... Maybe, i should cut the movie too... -
Hhhmm.. .at least it was wayyy better than mine, mine was calculated up to a whooping 72 hours! But then again i'm on a PIII 450MHz junk-machine
But i must say you beat me to having a larger fileAlthough mine was a longer movie...
padding or the last frame being encoded tens of thousands of times. it happened to me once, as well as some other posters here. re-multiplexing (which is what happened when you cut it) seemed to remove the extra frames, reducing the files size dramatically...
I tried remultiplexing the audio but the file size did not change, unfortunately....
Bitrate/QC same file size, is quality the same?
By marioval in forum DVD RippingReplies: 1Last Post: 4th Nov 2010, 08:56 -
Does half d1 alter file size at all or is it just how the bitrate is used?
By yoda313 in forum Video ConversionReplies: 14Last Post: 17th Oct 2010, 19:28 -
H.264 output file size too big vs WMV
By bijoythulas in forum Video ConversionReplies: 5Last Post: 29th Sep 2008, 21:21 -
Why does TMPGEnc DVD Author3 say that my file size is too big?
By jimdagys in forum Authoring (DVD)Replies: 4Last Post: 7th May 2008, 19:48 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 17:53
