I am completely new to this video capturing stuff. What are the minimum requirements I need and could someone give me some names of hardware I need that are good, TV Tuner cards/Capture cards, etc. Also some easy to use software. Thanks
1] A computer, which obviously you have
2] Some form of cap device (PCI/USB/IEEE-1394)
3] A CD/DVD recorder
4] Proper software to cap, convert (if needed), and burn.
5] PATIENCE
What exactly do you want to do? -
What I would like to do is take a 30-45 minutes sermon on Sunday morning from my minister using a VHS camcorder, don't have a digital camcorder yet but trying to work on that. I would like to then place the file on a web server for visitors to download if they would like to. Do you have any ideas that might make this an easy task?? Thanks for your response.
Originally Posted by D8TA
I've been really busy lately and am now reading to try this again. Is there any kind of system requirements? I am not sure if I need to get a new PC system basically I will be using an overclock Pentium processor running 240mhz, 64 meg RAM. I will be video taping a sermon that will run 30-45 mins and would like to take the video off the 8mm camcorder and place the file on a website so users can download the message. Roughly how much disk space will this take up? Can this be done with good results with the system specs above? I don't have a card yet but am looking for one...any recommendations? This is on a tight budget, most will be out of my pocket so I really don't need anything fancy. Thanks!
Audio help needed please
By BrainH in forum ComputerReplies: 1Last Post: 27th Jul 2010, 17:46 -
[ HELP NEEDED ] BD-ROM to BD-R 25 with BDRebuilder: how much CPU is needed?
By Tyrexionibus in forum Blu-ray RippingReplies: 1Last Post: 28th Oct 2009, 12:27 -
some help with ripbot needed
By davebarnes2009 in forum Blu-ray RippingReplies: 6Last Post: 12th Jul 2009, 15:07 -
Help with PC to HDTV Needed
By denzlite in forum DVB / IPTVReplies: 12Last Post: 13th Jan 2009, 16:34 -
Memory upgrade needed for TMPGENC DVD Author 3, advice needed
By Caned_and_Able in forum ComputerReplies: 8Last Post: 31st Jul 2007, 18:30
