Hi!
How can I convert Dolby Ac3-file into a Dolby Prologic? And can I add AC3-file into a XVCD? I hope somebody can help me with this problem...
Vesukka
If you make your VCD with either FlaskMPEG or DVD2AVI, then it will automatically downmix the Dolby Digital (AC3 5.1) to a Dolby Surround stereo signal that will be decoded if you have a Pro Logic receiver. You don't have to do anything extra.
You cannot put AC3 (Dolby Digital) on a VCD, SVCD or XVCD. You could mux the AC3 as the audio track, but I will guarantee that it will not play on almost any player.
Regards.
Michael Tam
w: Morsels of Evidence -
My personal 2cents on this matter...download Azid's .ac3 decoder....it does Dolby Surround downmix that sounds better & has more options than DVD2AVI & Flask provide
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Is there a GUI for that thing? I lost my little note on what to type in the command line. -
Azid GUI:
http://www.doom9.org/Soft21/Files/Audio/AzidGUIv0.5b.zip
I haven't checked out this latest version. The older one wasn't the most intuitive on what the options do. I was having to check the command line parameters that it was generating against the azid readme file in order to figure it out. But, it does work and sound great once the options are right.
No Dolby Pro Logic from AC3Machine
By jonghyunchung in forum AudioReplies: 9Last Post: 28th Jan 2009, 14:35 -
dvd audio and pro logic
By tommcd64 in forum AudioReplies: 1Last Post: 31st Oct 2008, 19:23 -
epson r260 cart problem - Logic
By mrtunes in forum MediaReplies: 11Last Post: 11th May 2008, 04:23 -
Cirrus Logic AccuPak Video download
By LoveMyslf in forum Video ConversionReplies: 9Last Post: 10th May 2008, 10:08 -
A Few Questions About Dolby Pro Logic
By seven_deuce offsuit in forum AudioReplies: 17Last Post: 29th Apr 2008, 15:08
