Hi i recently saw a copy of a movie in a format called superbitrate. I am assuming this means the video bitrate is alot higher and therfore the movie much larger. Is this so and if so has anyone been able to shrink a superbitrate movie to fit a dvd-r 4.7gb.??
Yes, new SuperBit DVD's use a much higher bitrate. As the file size is so much larger they usually drop the extras to fit it onto a DVD disc. Reading reviews, some movies look a lot better in SuperBit format while others are similar to their standard DVD releases.
How to achieve the maximum bit rate in variable bit rate mode ?
By Sxn in forum Newbie / General discussionsReplies: 42Last Post: 3rd Dec 2009, 12:53 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
Bit Rate
By shapper in forum Newbie / General discussionsReplies: 10Last Post: 2nd Jun 2008, 14:04 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 05:48 -
the right bit rate
By nojee in forum Video ConversionReplies: 5Last Post: 10th Nov 2007, 03:00
