whenI burn a vcd the movie comes out great but it always has the director talking about the movie. in the background you can here the movie audio too. how do I copy without the director talking over the movie.![]()
"Always" has the director talking ? Where are you getting the source from ?
Sounds like you're picking the wrong audio track. You're getting the one with the director commentary. Track 1 is usually the english DD or DTS track. That's the one that you should be using. If you use DVD Decryptor you can see which audio streams are on the DVD.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Burning 24-bit audio to CD
By Xoanon in forum AudioReplies: 27Last Post: 5th Oct 2009, 13:45 -
Taking Audio from movie file, then burning audio to cd-r
By Justnmnmn in forum AudioReplies: 5Last Post: 22nd May 2009, 17:44 -
Burning engine for audio CDs
By dadrab in forum ComputerReplies: 13Last Post: 29th May 2008, 15:23 -
No audio when burning a MPEG-2
By hostofsorrow in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2007, 08:13
