Ok. Uber-N00b. Read the tutorials.
Anyways, Trying to create VCDs. Filled out all the appropriate stuff when I signed up, So my hardware configs are there. I'm trying to replay my created VCD on my DVD Player, and it's not working. Using all the programs in this site's tutorials... Please help!
Results 1 to 16 of 16
NTSC VCD Template, 352 x 240. UYVY Interlaced. I know the tutorial says to use 24 bit RGB, but everytime I try to select it VirtualDub says that the format isn't supported.
edit: Corrected the template. -
At the risk of sounding like a total idiot, I must ask... Did you convert your AVI's to MPEG-1's using a program like TMPGEnc, and second, did you burn your MPEG-1's to CD using a program like VCDEasy (or I understand Roxio's Easy CD Creator Platinum can do this), or did you just burn the MPEG to a data CD? Burning the MPEG to a data CD won't work. There's a special format that a VCD must be in and VCDEasy knows how to do this...
CogoSWSDS -
Yeah, used TMPGEnc to encode, Nero to burn into VCD Format.
Found out in the chat last night I was using the wrong resolutionbut have that fixed now... I am starting to think my burner just doesn't like me.
I've heard of people having problems with Nero when trying to burn VCDs. Try VCDEasy - it works very well for me. Just click on "Tools" along the left side of your screen and scroll down to the VCD/SVCD Author/Burn section and you should find VCDEasy. Best of all, it's FREE!
CogoSWSDS -
heh, I'm trying to get VCDEasy configured after installing it. I couldn't get CDRDAO to work without ASPI, so I download ASPI, install it, and VCDEasy says the ASPI doesn't seem valid, and can't detect any drives. Can somebody please help?!
ASPI doesn't work with USB drives - is yours a USB drive or is it an IDE or SCSI internal?
CogoSWSDS -
IDE internal. Sony CRX160E.
Also, is there a minimum length of a VCD? I'm testing with 6 minute segments.. -
Have you check your DVD player compatibility ?
......some older models couldn't play CD-R disc
. Mine can accept CD-RW disc but not CD-R
It might be the problem. -
What's your DVD player brand and model ?
Have you tried to burn with 1X speed ?
Sorry for the irritating suggestion... -
lol, not irritating. Pioneer DV-343. Haven't tried 1x burn yet, trying to get VCDEasy to work, but the ASPI is giving me problems.
Well, here's a link to an FAQ about VCDEASY. It might help, just give it a try. http://www.vcdeasy.org/modules.php?name=_Guides&id=Cdrdao#ASPI
Good Luck 8) -
heh, Ok, I've done all that now. Thank you for the link
I'm starting to think my burner just can't handle it or something. Or it's the media. Which media do you recommend? Because I can get my VCDs to play on the VCD player I downloaded.
Help burning and playing VCD
By NLO_Cliff in forum Authoring (VCD/SVCD)Replies: 12Last Post: 16th May 2011, 09:55 -
trouble playing dvd
By speedoman955 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Dec 2009, 07:08 -
Having trouble playing 1080p
By godvsnietzsche in forum Software PlayingReplies: 8Last Post: 24th Nov 2008, 18:09 -
trouble playing .avi files
By starkythesparky in forum Software PlayingReplies: 5Last Post: 12th Jun 2008, 22:54 -
Having trouble playing old vhs-c tapes
By Columbusbill in forum Newbie / General discussionsReplies: 5Last Post: 31st Dec 2007, 21:49
