I am very new to video authoring. Before I go too far and waste any DVD-R media, I was wondering if it is possible to record VCDs to a DVD disk. Is this procedure any different than burning VCDs to a regular CD? Is there a different approach that I should be aware of? I simply want to put a lot of video onto a dvd disc.
Thanks,
Brian
There is a guide that doesn't include reencoding the files but it may not work on all standalone players. Take a look here http://www.vcdhelp.com/vcddvdr.htm
the way i do it is re-encode the vcd mpeg to dvd mpeg using tmpgenc, then author and burn using ulead dvd workshop, just make sure you get the update patch for dvd workshop.this corrects an audio sync prob
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 15:35 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 12:15 -
Playing DVD-RAM Video Disk On PC
By Rayvyn007 in forum Software PlayingReplies: 2Last Post: 23rd Jan 2008, 13:01 -
How do I transfer Video from PC to DVD Recorder using a RAM Disk
By barry_w2 in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 13:14
